Company Logo Shop Now
Order Ford 800 Parts Online
Ford 800 fuel tank aftermarket rear bracket
bigbleeker
04-14-2017 16:31:06
I purchased a aftermarket tank used and rear bracket that bolts to corners of tank and then to tractor missing somebody have one .thanks tom
Royse
04-15-2017 11:42:50
 Re: Ford 800 fuel tank aftermarket rear bracket in reply to bigbleeker, 04-14-2017 16:31:06
Is your email address spelled right? Email wouldn't go through.
Royse
04-15-2017 10:02:33
Was just looking around for that air breather tube.
Don't think I have one of those other than N series.
Royse
04-15-2017 09:34:20
Here's the bracket.
third party image
third party image
third party image
Royse
04-14-2017 20:23:22
Can you post a picture with a tape measure next to it?
bigbleeker
04-15-2017 10:15:03
 Re: Ford 800 fuel tank aftermarket rear bracket in reply to Royse, 04-14-2017 20:23:22
Ilike your pics better nice measuring. would you send iam kal mi your lansing area.thatlooks like the right one
royse
04-15-2017 10:27:03
 Re: Ford 800 fuel tank aftermarket rear bracket in reply to bigbleeker, 04-15-2017 10:15:03
I don't see your email open. Mine should be. If not it's RoyseTractors at gmail.com
bigbleeker
04-15-2017 11:05:13
 Re: Ford 800 fuel tank aftermarket rear bracket in reply to royse, 04-15-2017 10:27:03
Tomblater@att.net
Royse
04-14-2017 17:29:14
I have one off a Jubilee tank. They are different sized
tanks, but I'm not sure the brackets are any different.
Maybe someone can tell us for sure.
bigbleeker
04-15-2017 07:28:14
 Re: Ford 800 fuel tank aftermarket rear bracket in reply to Royse, 04-14-2017 17:29:14
third party image
third party image
third party image
fuel tank is 16 1/2 by 28''. Rear hole for bracket to mount to tank are 15 1/4. Do you have a air breather tube for a 134 cubic inch ? Its not the 90 degree.
bigbleeker
04-14-2017 19:30:00
It has only one hole in center of tank for drain cock the bolt kind .there is no sending unit hole .maybe someone will know if the two diffrent tanks use same bracket .
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
Latest Ad: Needing good 70 series fenders. No rust or dents preferred. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
