marcusmerritt
Ford 2000; 3 cyl. gas; 4/1 trans....Needed to use my tractor today and got it to run for maybe 5 seconds and then it dies and won't restart. It has sat for maybe a month or so since last being run. Battery is fully charged. I slightly moved the distributer one way and then back the other since the rotor looks like it has been contacting on the corner of the brass contact rather than somewhere in the middle. Wiped out the distributor cap and the rotor is good. It's full of fresh non-ethanol gas, new starter cable, and tight electrical contacts. I know I've flooded it now so am letting it dry out. The initial sucessfull crank this morning was with no throttle and no choke. I have some starter spray that I can shoot into the intake but don't like cranking it that way. Any ideas?
Thanks.
Thanks.
