Brian J in MN
OK gang here are the pictures showing the sight glass and how I mounted an external filter for the s-o-s transmission. The bulkhead fittings on the tranny are 3/8 pipe thread. I used both compression and flare fittings with short pieces of 1/2 in copper tubing and used oil resistant hose to make up the rest of each line(easier to get around corners than trying to bend that size tubing).
I hope this gives everyone a good view of how I did it. Filter base is a NAPA 4267 with a NAPA 1622 filter. This filter has a built in bypass valve at 7-9 psi like the original filters.
Brian
Brian
