whitcarroll24
We have had issues with our 6640 cranking. It is dragging really slow like it doesn't want to turn over. We started by replacing the battery. Next we replaced the starter and solenoid because the hot lead at the starter would get red hot while trying to crank it, so we figured the starter or solenoid were shot. We also replaced the alternator because it was bad. So now we have a new battery, starter, and alternator but it still will barely turn over and will not crank. And the hot lead on the starter almost catches fire it gets so hot, and we are not trying to crank it for more than 10 seconds or so. We can pull it off using our other tractor and it will run. If it is good and warmed up we can usually turn it off and crank it back up if we do so within a couple of minutes. But if it sits for any longer than that it will not crank and starts doing the same thing again. Any ideas? I'm about to the end of my rope with this thing.
