HomesteadDan
New User
First time posting - 1964 ford Ag. light industrial 4000, 172 CID 4cyl. (41305) select-o-speed trans. 540 PTO, front loader and a removable 753 backhoe. History - I purchased the tractor 2 years ago an used it for year. Changed oil and filter a couple of times. Ran a little week but I love this tractor. I changed plugs, distributor cap, rotor and points once, after it quit running, an it fired back up like usual.
October of last year, I had to replace the water pump (I think I over tightened the belt), and decided to power wash the machine. I started it up and sprayed it off good. I let it run a little longer and then shut it off. Next day I decided to remove the backhoe to repair a leaky right rear tire and to power spray the hoe. I started it up, got to flat ground, turned it off and removed the backhoe. It turned over really slow and wouldn't start again. I checked for moisture in the distributor, and anywhere I thought it might be a problem, etc.. it sat for a few weeks while I asked around and tried to figure out what to do next.
I discovered worn but working distributor cam weights, a starter motor that was filthy but cleaned up OK and turned fast when attached to a 6 volt battery and a host of old worn wiring. I replaced suspect wiring. It still struggled to turn over and wouldn't start so I got a mechanic friend to look at it with me. We found very low compression, and he commented that he didn't think the starter was turning fast enough. Based on the compression - I decided to pull the head and have a look see. over the next few months I have....
Head cleaned up and a machine shop did the valves.
After I found a couple of broken rings,I carefully honed the cylinders an installed...
New rings and main bearings.
New starting and charging circuits wiring
New plug wires, spark plugs, distributor cap, points,condenser,& coil
New starter
New battery
I also decided, while it was down, to replace the rear wheel bearings to get rid of the side to side slop in the rear end.
I have also replaced the rear end gear oil, hydraulic oil, and transmission hydraulic fluid and clean up the transmission screen filter.
Now - after all this - It still won't turn over. Starter won't make one complete turn.
I suspect some rusty, locked up something or other but could sure use a point in the right direction. I am thinking about removing the front cover to look at timing gears and the governor assembly. Any ideas before I waste more time and money? Thanks to any who respond
New starter
New battery
