Company Logo Shop Now
Order Ford 881 Parts Online
881 trans/hyd reservoirs
Brian J in MN
02-27-2017 12:06:24
Has anyone combined these together? I did some rough measuring and the hydraulic level would be quite a bit higher than the transmission oil level, but I was wondering if it would be possible to make an opening so these two could be combined.
My reason is once I get the external filter mounted, I could have the hydraulics filtered as well.
Brian
Brian J in MN
02-27-2017 18:39:26
 Re: 881 trans/hyd reservoirs in reply to Brian J in MN, 02-27-2017 12:06:24
Got it, just a thought.
Brian
Dean
02-27-2017 16:16:10
Overfilling the transmission is likely to cause oil leaks around the input shaft and onto the clutch. Not a good idea.
That said, it is not uncommon for worn seals to allow oil migration between all three sumps.
Dean
Latest Ad: need 3 point arms (with the ball) especially need the [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
