Company Logo Shop Now
Order Ford NAA Parts Online
Jubilee Hyd Pump
Gunner 10
01-08-2017 09:45:38
I'd like to thank all who responded to my perceived clutch problem. The engine after the overhaul is back in place, with most of the bucket frame bolted in. My question is, since I had the hydraulic pump removed for the overhaul is mandatory to bleed the pump on startup? Since the distributor was also removed, although I marked its position, being a realist there is going to be a lot going on and I really wanted to get an idea if the pump needed to be bleed and how long could it run without bleeding before one has a problem. Anyone has any experience with the pump, it's a piston type?
THanks
old
01-08-2017 10:57:38
 Re: Jubilee Hyd Pump in reply to Gunner 10, 01-08-2017 09:45:38
I would prime the pump but once that is done you should not have to bleed it
Gunner 10
01-08-2017 12:24:26
 Re: Jubilee Hyd Pump in reply to old, 01-08-2017 10:57:38
okay, how do you prime a pump that's solid with tubing, thru the bleed hole?
old
01-08-2017 13:05:26
 Re: Jubilee Hyd Pump in reply to Gunner 10, 01-08-2017 12:24:26
Yep what you call a bleed hole is the prime hole
Gunner 10
01-09-2017 09:06:29
 Re: Jubilee Hyd Pump in reply to old, 01-08-2017 13:05:26
Okay. I'll give it a try, once it warms up.
Thanks
old
01-09-2017 09:12:57
 Re: Jubilee Hyd Pump in reply to Gunner 10, 01-09-2017 09:06:29
When I prime one I like to use a thick oil like 80W-90 but you do not need a lot of it to prime it
Today's Featured Article - Talk of the Town: What's in Your Tractor's Toolbox? - by Staff. This recent discussion on the Tractor Talk discussion board here at the on-line magazine drew so much response and proved to be so interesting that we wanted to share it with you here. The names of the people participating in the discussion have been left out to "protect the innocent" (to quote a once-popular television series). ... [Read Article]
Latest Ad: McCormick Deering 22-36 Tractor has been restored by previous owner. Runs great looks great. Tractor has automotive paint that is really sharp. Tractor shows really well. Would make a nice addition to a IH collection. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
