Company Logo Shop Now
Refilling loader ressy
85burbanator
01-02-2017 14:45:27
Did an alternator conversion in my free time and the original belt was to long. Machined the old genny pulley to fit the alt. And put on a shorter belt. Had to take the front pump loose for the loader and found a split lower hose coming from the resivoir for the loader (730) replaced that and buttoned everything up. What's the best way to bleed the air? Just fill it and run it? The fluid in it was milky but didn't feel or smell like water had made its way in, that isn't normal is it? Drained about 6 gallons give or take
85burbanator
01-02-2017 16:01:18
 Re: Refilling loader ressy in reply to 85burbanator, 01-02-2017 14:45:27
That was my general concensus. It usually smelled funky though from what I remember.
So new fluid and self bleeding. Thanks. I'll top it off and change the filter and fluid again in the spring.
All cylinders are collapsed right now so all the old stuff is what's left in the lines.
RickB
01-02-2017 17:20:31
 Re: Refilling loader ressy in reply to 85burbanator, 01-02-2017 16:01:18
And the rod side of all the cylinders.
RM-MN
01-02-2017 15:34:58
Hydraulic oil should look like honey. If it is black it is from a little water. If it is grey, that's more water. Milky white...Dump it out and put in fresh before all the water does some real damage.
Andy Wickiser
01-02-2017 15:15:50
The loader system is self-bleeding, just cycle all the cylinders a few times.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: DEARBORN SIDE DELIVERY RAKE CAN BE REPAIRED AND belly mount MOWER FOR PARTS ONLY.. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
