Ford Tractors Discussion Forum |
5000D clutch
Author |
[Modern View] |
Doug Wi
12-29-2016 15:02:33
Hooked the 5000 to the haybine this summer and pulled up to the shop. Started the tractor in neutral, then jumped on to go and it would not go into gear. The gears would just grind like you weren't stepping on the clutch. Monkeyed with it abit, but didn't cure anything, so shoved it aside and put another tractor on the haybine. Left the clutch linkage unhooked. This fall I used it on the blower by shutting it off to shift gears and got it into position. Got it into the shop today, hooked the clutch linkage back up and it worked fine. Anybody got a clue as to what is happening? Hate to split it if I don't need to, but hate to have it fail when its needed.
jsp5755
01-03-2017 10:54:58
Re: 5000D clutch in reply to Doug Wi, 12-29-2016 15:02:33
My 5000 clutch would get stuck if it was not used for a while (more than 4 weeks). It has done this maybe 5 times in the last 16 years. Each time we would start the tractor in gear and drive it down the road and hold the clutch down and tap the brakes....each time the clutch would break back free. It's been a while since this has happen....but the tractor gets more frequent use now.
Destroked 450
12-31-2016 07:59:31
One time a cousin borrowed dad's 850 and brush hog to mow a few acres behind his house, when he got done decided to clean the tractor and mower up before bringing it home so he washed it. After it had dried off he when to bring it home and found the clutch was stuck, after telling us what he did we rocked the tractor back and forth a few times and the clutch came loose. We're guessing the rapid cooling and condensation from washing the tractor while it was hot caused the clutch to stick to the flywheel.
From that day on we never washed a hot tractor, we let them cool off before washing. That clutch never stuck again.
Doug Wi
12-30-2016 19:16:45
Have played with it again and still seems to work fine. will take it out and drive some and then grind a batch of feed tomorrow, if it still works think I'll leave it and hope for the best.
RodInNS
12-30-2016 18:15:11
Could be stuck clutch disc... could be bad pilot bearing. I put a clutch in my 5000 this summer and the NEW pilot bearing is bad. SO now I got to split the old lizzard again... and this time it will get a non-china bearing. Rod
Destroked 450
12-29-2016 18:34:48
The clutch was sticking on my 5000, pulled in apart and found the input shaft seal was letting trans oil in to the clutch housing and getting on the disc.
Pulled my 4500 apart for a stuck clutch from setting, water and oil pored out of the clutch housing, the drain hole in the bottom of the clutch housing was plugged up, replaced the input shaft seal while I was there.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
Latest Ad:
need 3 point arms (with the ball) especially need the
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
