Company Logo Shop Now
Order Ford 600 Parts Online
600 vs 800 rear axle ratio
markct
11-29-2016 03:15:43
I have been wondering if the 800 tractors had lower gears to make up for the larger tires. I have an 800 rear end on a 600 tractor and it's seems slightly slower so it got me wondering
JMOR
12-01-2016 06:54:34
 Re: 600 vs 800 rear axle ratio in reply to markct, 11-29-2016 03:15:43
word of caution: don't get too hung up on ground speed. I have two virtually identical 8Ns and one always travels faster than two. Identical tires, even brand/age, identical transmission and differential gears.......reason is that governors do not govern tho same speeds. On later tractors, all optional transmissions do not have identical gearing, either.
CTPhil
12-01-2016 06:30:13
This may or may not be helpful but an observation. I have both a 2600 and 4100, both 1978. Despite having smaller tires, the 2600 is way faster.
JMOR
11-30-2016 08:25:23
40 teeth/6=6.6666 and 43 teeth/6= 7.16666
Machnegative
11-30-2016 05:35:03
Got to looking at the same page in the 600/800 manual as above in the 2000/4000 manual and found the same info on rear end ratios. Just a little lower ratio in the 800 series. third party image
keith williams
11-30-2016 07:44:49
 Re: 600 vs 800 rear axle ratio in reply to Machnegative, 11-30-2016 05:35:03
I think that is just a rounding thing. I would guess the gears are the same. 800 /801 /4000
To the other poster, different ratios means different gearing.
IMHO
Keith
Montana55
11-30-2016 05:06:01
Looking at Machnegative's "ground and engine speeds", I would think the point of comparison is direct drive forward, in other words, what is the ground speed in high gear.
Model 640 is 13.67 MPH, model 650/660 are 14.73 and model 850/860 are 14.10.
I don't know what the original tire sizes were, but to me it appears that the 650/660 had the same ring and pinion as the 640, just larger tires. Then the 850/860 either had shorter tires or lower gearing.
keith williams
11-29-2016 07:45:10
third party image
third party image
From 2000 & 4000 Manual.
Machnegative
11-29-2016 05:36:49
Havent actually counted teeth, but here is a chart from a manual that seems to support your hypothesis of different ratios.
Jeff
third party image
markct
11-29-2016 05:47:28
 Re: 600 vs 800 rear axle ratio in reply to Machnegative, 11-29-2016 05:36:49
Interesting, so it would seem that even with the larger tires the overall speeds are slower on those tractors, thus a lower rear end for sure. I have the smaller 600 size tires on it so it's definitely slowed down a fair bit.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: Shaw due all tractor [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
