Company Logo Shop Now
Power Steering line leak
Dchilds
11-23-2016 08:08:54
Does anyone have a brief explanation on how to fix a leak in the power steering line (from pump to valve/steering column) on a Ford 3000? I have a pin hole leak at the elbow where the line turns down toward the pump.
It appears to have been soldered at some point and that's now failing. I was thinking maybe cut the elbow out and replace with some kind of 45 degree fitting....have to use/rent a flare tool (which I have not experience with).
Any help is appreciated.
jtwat
11-24-2016 18:19:17
 Re: Power Steering line leak in reply to Dchilds, 11-23-2016 08:08:54
You have to braze steel lines to repair. Solder will not stay.
If the hole is at the 90* bend, you may be able to cut it out and replace the bend with a 90* brass compression fitting.
Dchilds
11-23-2016 19:35:22
I called a local guy who said he could fix it - "no problem". I'll take it over early next week to see what he can do. Thanks for the suggestion!
BobReeves
11-23-2016 09:13:28
Had a fitting leaking on my 3000. Removed the line and took it to a local shop that made me a new line complete with the proper bends. A local hydraulic hose shop may be able to help or point you to someplace that will.
Today's Featured Article - Recollections of a John Deere GP - by Charlie Cook. I grew up on my dad's 280 acre general farm in Western Michigan. Dad's only tractor when I was very young was the old GP. My first recollection of this tractor was when dad allowed my brother and myself to ride on the tractor with him driving. One of us would sit on the left fender (away from the clutch) and other would sit on the gas tank and hold onto the crankcase breather pipe. ... [Read Article]
Latest Ad: Wanted front suit case weights and rear wheel weights for a 1456 international. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
