Company Logo Shop Now
Order Ford 3000 Parts Online
Changing coolant ford 3000?
BobReeves
11-21-2016 04:19:15
Guess nothing on theses old tractors is easy, on the down side of giving my 71 3000 diesel some much deserved TLC. Last item on my list was replacing the antifreeze, know it hasn't been done in the 10+ years I have owned it and figure it's due.
So OK I drain the engine, found a petcock on the side of the block and got about 4 gallons give or take. Book says 17.something quarts. That part went well. Now I start filling it back up and after two gallons radiator is full and it won't take any more even after letting it set for several hours and starting it. Only let it run for a few minutes for fear of overheating the block.
So what is the trick to making sure the block and radiator are both full of coolant?
BobReeves
11-22-2016 05:35:39
 Re: Changing coolant ford 3000? in reply to BobReeves, 11-21-2016 04:19:15
Well I now feel like an idiot, just goes to show how perceptions can be really really wrong. You guys hit it on the head, I only had a little over two gallons in my drain pan.
What came out was pretty clean and still green so I'm calling it good with just replacing half of it. I will go ahead and add the conditioner after I have ran it to be sure everything is mixed well.
JTWAT
11-21-2016 16:53:22
Thermostat can be found at parts store. Take old one out and take it with you. Get the 50/50 mix coolant and fill radiator to top. Start tractor and let it run until thermostat opens and the air in block is released. Top off radiator about 1 inch below top. If you want to add the additive, get it at NAPA.
Rickb
11-21-2016 12:09:39
Did you drain the radiator and block, or just the block?
If just the block, you got more like 2 gallons out of it, not 4.
BobReeves
11-21-2016 14:45:20
 Re: Changing coolant ford 3000? in reply to Rickb, 11-21-2016 12:09:39
Just opened the petcock on the block, drained into a 5 gallon catch pan and let it drain overnight. From the looks of what is in the pan I got really close to 4 gallons.
Auto mechanic friend said to raise the front up which would be pretty easy to do with the loader. May also try hitting the thermostat with a heat gun in hopes it will open and let the air out.
I did pick up a new thermostat from the local NH dealer. New one has no hole and would guess the one in it doesn't either.
RodInNS
11-21-2016 14:55:37
 Re: Changing coolant ford 3000? in reply to BobReeves, 11-21-2016 14:45:20
If you only opened the one drain... I'd wager there's a good gallon in there yet. I sometimes pull the lower rad hose off the rad but given you have a loader on a 3000 I'd probably avoid that too.
Rod
BobReeves
11-21-2016 15:03:02
 Re: Changing coolant ford 3000? in reply to RodInNS, 11-21-2016 14:55:37
Ya working around that loader is a real PTA but in the long run happy to have it.
Tomorrow before I get too carried away, I will put what I drained out into jugs and see exactly how much it is.
RodInNS
11-21-2016 08:49:23
I run FLeetGuard DCA4 conditioner. New diesel rated coolant should have the correct additive package.... ~Should~ being a very large word. These blocks were known to perforate back in the day... even when new, with new coolant... so I always just add a bottle of conditioner. As far as filling those things is concerned... usually I find you need to run them for a bit to get them to burp, then top it off. If the thermostat hasn't been changed in a dogs age, it's not going to hurt to change it. I use 188 (88c) stats in the diesel engines.
Rod
BobReeves
11-21-2016 08:12:22
Found this at O'Reilly's, says it does everything.
third party image
Ultradog MN
11-21-2016 04:52:52
Don't forget to add the coolant conditioner to keep the block from perforating.
Those diesels are known for that.
BobReeves
11-21-2016 07:36:12
 Re: Changing coolant ford 3000? in reply to Ultradog MN, 11-21-2016 04:52:52
Thanks, Called New Holland to check on the thermostat and asked about an additive. They just tried to sell me branded antifreeze saying it had everything in it that it needed. No real surprise..
What additive do I need to buy?
Billy NY
11-21-2016 08:02:55
 Re: Changing coolant ford 3000? in reply to BobReeves, 11-21-2016 07:36:12
New Holland Part# showing on their coolant conditioner is FW-15. Napa I believe has an equivalent as well, I've used it in our 3600.
showcrop
11-21-2016 04:29:49
You may have to remove the T'stat. The tiny hole in it could be plugged so that the air can't vent out of the block and head.
BobReeves
11-21-2016 06:57:41
 Re: Changing coolant ford 3000? in reply to showcrop, 11-21-2016 04:29:49
Makes sense, is the thermostat and gasket something I can pick up at O'Rileys or does it have to come from NH? If I remove it might as well install a new one.
Today's Featured Article - Talk of the Town: What's in Your Tractor's Toolbox? - by Staff. This recent discussion on the Tractor Talk discussion board here at the on-line magazine drew so much response and proved to be so interesting that we wanted to share it with you here. The names of the people participating in the discussion have been left out to "protect the innocent" (to quote a once-popular television series). ... [Read Article]
Latest Ad: McCormick Deering 22-36 Tractor has been restored by previous owner. Runs great looks great. Tractor has automotive paint that is really sharp. Tractor shows really well. Would make a nice addition to a IH collection. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
