Company Logo Shop Now
Order Ford 4000 Parts Online
Ford 4000 needs brakes how long of job
jmducks1
11-20-2016 18:46:49
Ford 4000 disk brakes how long does it take to install new brakes? Any pictures of the brakes
Cathal 78
11-22-2016 13:58:14
 Re: Ford 4000 needs brakes how long of job in reply to jmducks1, 11-20-2016 18:46:49
I did it last year in a day losing the brake linkages wasn't handy all sized up and lift the cab but you do need a engine lift
RodInNS
11-21-2016 18:07:10
Depends...........
If it's an open station, no roll bar, you have an engine crane or something handy to lift the axle housings... and you don't mind cutting the old U-bolts off the fenders... and you have an air gun of sufficient capacity... you can probably do each side in 3-4 hours provided you don't go off on any tangents (axle seals) and everything goes right.
If you're dealing with a cab, and especially with a loader... all bets are off. Time will then be determined in terms of how long it takes you to wrestle that stuff out of your way.
Rod
Sean in PA
11-21-2016 08:56:44
Sorry, didn't notice you said "disk brakes" in the first post. Please disregard my previous post, as I can't edit it.
Sean in PA
11-21-2016 08:55:23
All of the responses that you have gotten so far assume that it is a 3 cylinder 4000. If it is the earlier 4 cylinder 4000 then it is much easier in that they are dry drum brakes like a 1960's car.
showcrop
11-21-2016 04:35:57
Notice that the younger guy is working hard enough that despite being able to see their breath he needed to remove his sweatshirt.
Ultradog MN
11-21-2016 01:39:40
I haven't done it.
There's a pretty good video on youtube where they do the brakes on a 4100 = same as a 4600 = same as a 4000 Couple of German guys iirc. They do the whole job at about 3X camera speed so the video is just a few minutes.
It didn't look too hard.
If the link below doesn't work just search for Ford 4100 brakes .
Hard to do from this phone.
Today's Featured Article - Recollections of a John Deere GP - by Charlie Cook. I grew up on my dad's 280 acre general farm in Western Michigan. Dad's only tractor when I was very young was the old GP. My first recollection of this tractor was when dad allowed my brother and myself to ride on the tractor with him driving. One of us would sit on the left fender (away from the clutch) and other would sit on the gas tank and hold onto the crankcase breather pipe. ... [Read Article]
Latest Ad: Wanted front suit case weights and rear wheel weights for a 1456 international. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
