Soundguy generator
matthies
So I put the ground to the case and powered the F and G terminals and still no go to motor, what did I do wrong. Even spun the pulley to help but no go.
I've never heard of Soundguy generator. Perhaps that's your problem. :lol: And we sure wouldn't want to generate any more Soundguys anyway! 8)
If you can power the field and armature of a 53+ ford / lucas genny while it's case is grounded, and it won't motor, it needs to go to the doctor.
Could be a few things.
Brushes gone... field open.. etc. Both.. etc..
Brushes looked good, I will check the fields and see what I find. Probably cheaper to change over to 12 volt. Will see. thanks chris
In good+ condition units, with perfect bearings/bushings, yes, some will weakly motor on residual alone, but you should be able to see a motoring difference when there is field current.
The average 70 year ok Gen I see usually won't motor much at all without son field current.
