Company Logo Shop Now
DPA Pump reseal
JTWAT
11-11-2016 14:08:42
I'm in the process of re-sealing my Lucas DPA injector pump on my 4000. Have it torn down and in the ultrasonic cleaner.
My question is: can the drive bushing be replaced in the case? I can see from the inside where it can be driven out but have not found a replacement bushing online.
Dieseltech
11-11-2016 14:38:52
 Re: DPA Pump reseal in reply to JTWAT, 11-11-2016 14:08:42
That application has no replaceable bushing, drive hub rides directly in the aluminum housing..
JTWAT
11-11-2016 15:02:30
 Re: DPA Pump reseal in reply to Dieseltech, 11-11-2016 14:38:52
You are correct. I just removed the case from the cleaner and see that. It was brown before cleaning and looked like dirty bronze.
Any idea what a case costs? Or how much play is acceptable?
Dieseltech
11-11-2016 17:26:44
 Re: DPA Pump reseal in reply to JTWAT, 11-11-2016 15:02:30
Hub end play should be .010 inch or less, never have seen the bore wear bad enough to need replaced. End play wear is more common.
JTWAT
11-11-2016 20:12:51
 Re: DPA Pump reseal in reply to Dieseltech, 11-11-2016 17:26:44
Thanks, what type and size of tubing do you use for the fuel return tubes between the injectors and fuel tank?
Dieseltech
11-12-2016 05:12:24
 Re: DPA Pump reseal in reply to JTWAT, 11-11-2016 20:12:51
Been awhile, but the last time those were needed just got the complete line and fitting assembly from New Holland.
JTWAT
11-13-2016 12:57:20
 Re: DPA Pump reseal in reply to Dieseltech, 11-12-2016 05:12:24
Have everything clean and reassembling. I have a question concerning the transfer pump piston.
My book shows a o-ring on it where is seats in the valve. When I removed it for cleaning there was a red fiber washer stuck to it.
I don't see any washer or o-ring in my kit that fits the plunger. Is this seal needed or will it seal good enough without one?
Thanks
Dieseltech
11-13-2016 14:07:50
 Re: DPA Pump reseal in reply to JTWAT, 11-13-2016 12:57:20
If you mean the transfer pressure sleeve, piston and spring assembly there's no O ring used. The sleeve does use a small gasket to seal the lower shoulder inside the end cap.
Today's Featured Article - Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin ... [Read Article]
Latest Ad: Looking for a John Deere 50, 520 or 530 in good shape and preferably with power steering and three point. May be interested in a 620 or 630. Thank you. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
