5 speed double clutch install
The 5 speed double clutch on this sight says no alignment tool needed. When I install my old clutch to motor I
will not need one either . is this because trans shaft spline spine separetly it wouldnt do me no good .any in
sight would in reinstall would be nice
I think it comes with a plastic tool, I bought a single disk clutch from this site they sent an alignment tool that would also work for the double
No tool needed. Assuming you didn't drop the clutch on the ground after you removed it, the discs should be tight and centered in the pressure plate assembly. The discs are held tight in the pressure plate when removed from the flywheel - this is the way it is designed.
Bern is correct. Your clutch will unbolt from the flywheel as an assembly .
Bern is right, no alignment tool is needed. The clutch pack is aligned during assembly. You simply unbolt the old pack and bolt on the new. Its the easiest clutch I've done.
