Company Logo Shop Now
Order Ford 601 Parts Online
sway bars (601 Ford)
grayrider
10-02-2016 15:29:48
third party image
third party image
third party image
third party image
Anybody thought of this before? Been fighting my sway bars for years on my various tractors, when backing up to an implement their always falling down, have tied them over the years, put bolts through them and lift arm to hold in place while backing up, you name it and I've probably tried it. Today I welded some bolts to each sway bar and can now lay them across the lift arm and back up with out them falling off, can drive all over property without an implement and they will now stay put, somebody else has thought of this before me I'm sure....
Tall T
10-10-2016 10:57:00
 Re: sway bars (601 Ford) in reply to grayrider, 10-02-2016 15:29:48
My hybrid sway bar setup.
They have lower link balls on the fender ends and I put a big flat washer on each to to hold the ball tight & square.
I usually undo and reconnect when connecting implements.
Regular lynch pin rings still lock well with them too.
third party image
GVSII
10-07-2016 17:31:50
All clever ideas to keep from bending those bars.This is what I did:I took 2 pieces of flat stock about 7 inches long and bent them into an "S".One leg of the S goes over the lift arm,the other leg goes under the stab. bar.
Jim in N.M.
10-03-2016 08:50:49
I did mine several years ago by using 1/2 of a large washer welded to the top of the lift arm 4in. in from the end. Works great!!! Jim in N.M.
steve19438
10-03-2016 04:00:13
I use electrical ties to keep em place.
Kirk-NJ
10-03-2016 01:37:45
third party image
Farmer Dan on the N board has been using these stays for years. Basically the same thing only welded hook.
Kirk
showcrop
10-02-2016 17:52:08
I call mine "stays"
marcusmerritt
10-02-2016 16:45:02
Will try to post a photo of my solution of keeping the sway bars on my Ford 2000 3 cylinder gasser. Basically, added a clevis hitch to each sway bar and then suspend them with a chain that hangs from each fender. Keeps them up and out of the way and I haven't backed over one yet. third party image
Larry NCKS
10-02-2016 16:39:58
I like it!
Latest Ad: need 3 point arms (with the ball) especially need the [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
