Company Logo Shop Now
Order Ford 4000 Parts Online
4000 3 cyl oil pressure update
Ford9000puller
09-07-2016 18:16:04
You guys called it. Hex on pump shaft is almost rounded off. Will catch once in a while spinning it by hand. Looks like they didn't shut it down soon enough #2 rod bearing and journal is pretty rough. Been bored .030 already and wore some. Looks like it will need sleeved back to std. We knew it probably wouldn't look good inside so not a total surprise. Putting a same as new 602 picker on it when it's done so it should be a corn picking son of a gun when it's done
Destroked 450
09-09-2016 09:04:00
 Re: 4000 3 cyl oil pressure update in reply to Ford9000puller, 09-07-2016 18:16:04
Look below my user name
John
Destroked 450
09-08-2016 20:00:13
I don't have any good pistons but should have a couple of good cranks, boreable block and gas heads for a 192 along with some misc stuff. Also have a running 192 diesel off of a late model 3930 I don't need.
ford9000puller
09-09-2016 09:01:37
 Re: 4000 3 cyl oil pressure update in reply to Destroked 450, 09-08-2016 20:00:13
Thats good to know!! I think this crank will turn but if not I may give you a shout. Where are you located?
Destroked 450
09-08-2016 19:51:30
I have the one dad bought new in 64 but it's completely worn out, we had the only picker in your neighbor hood so it picked 125-150 acres a year thru the 60's and early 70's mounted on a Fordson Dexta.
I have picker brackets on my 4000 and 4000SU along with the brackets that where on the 881 diesel I bought with this picker, mainly like to mount the picker on my 4000 as it's 30" rear tires lifts the picker up higher so the elevator clears a gravity wagon bed better.
We only pick around 10 acres a year to grind for cattle feed and a pull type would be simpler but dad had me running his picker when I was 9 years old, I grew up running a 601 picker, loved running it then and still do today.
Ultradog MN
09-08-2016 12:44:20
Good update.
I have seen those hex shafts worn enough that I replaced the pump to be on the safe side but never seen one bad enough to stop turning.
That gasser is likely a 192. If it was a 201 I have a set of standard pistons and rings I could sell you cheap. They came out of one of those school tractors.
Might have a couple hours on them.
ford9000puller
09-08-2016 19:34:34
 Re: 4000 3 cyl oil pressure update in reply to Ultradog MN, 09-08-2016 12:44:20
Yea its a 192. Thanks for the offer though I really appreciate it. I'm a Tisco, A&I and Atlantic parts dealer and non of them have the 192 pistons available. Found some other places so should be able to get it together.
Destroked 450
09-07-2016 22:00:00
Just seen the picture in your other post, that tractor has wide front axle, do you have the narrow front end pedestal to put under it for using the picker, two roll picker wont mount on a wide front tractor.
Destroked 450
09-07-2016 21:33:13
They make a .040 over piston for that engine that would save on the cost of sleeving.
Haven't see a 602 in several years, back in March I picked up a nice 601 that hadn't been out of the barn in over 30 years. Haven't tried to run it yet but everything looks good. I'm planning on it replacing my old 601 that's showing a lot of wear and has the bottom of the elevator rusted out.
Would you happen to have a good quartz roll you would be willing to sell, I have a good rubber roll but my quartz roll is about shot.
ford9000puller
09-08-2016 11:07:24
 Re: 4000 3 cyl oil pressure update in reply to Destroked 450, 09-07-2016 21:33:13
Yeah we've got a narrow front to put under this tractor. One cylinder is pretty rough and I don't think it will clean up at .040. Decided since we have it apart just to go the sleeve route and hopefully stay away from any cylinder wall problems like some of the 4 cylinder engines have given. Sounds like you got ahold of a nice 601 picker. What tractor do you run your picker on? I don't have any extra rolls that I know of. We've got a total of 4 602 pickers and a old style 1 row that we pick and play with so try to hold on to all the parts we can get. I've got some videos of them running on youtube under ford9000puller. I think I am going to try to find an epoxy and mix in some quartz or granite and try to recoat a couple roles and see if that will work
Today's Featured Article - Recollections of a John Deere GP - by Charlie Cook. I grew up on my dad's 280 acre general farm in Western Michigan. Dad's only tractor when I was very young was the old GP. My first recollection of this tractor was when dad allowed my brother and myself to ride on the tractor with him driving. One of us would sit on the left fender (away from the clutch) and other would sit on the gas tank and hold onto the crankcase breather pipe. ... [Read Article]
Latest Ad: Wanted front suit case weights and rear wheel weights for a 1456 international. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
