Ford NAA Spark Plug Problem
Author |
Chip
04-08-1999 12:36:37
Hi, A friend has the above tractor and has had a reoccuring problem of the same plug not sparking. His #4 plug stops firing and when replaced with a new plug, the motor runs fine. Compression check is good, wires are ok and so is cap. Any Ideas?
RK Smith
04-21-1999 18:20:00
Re: Ford NAA Spark Plug Problem in reply to Chip, 04-08-1999 12:36:37
you can't be positive the plug wire is ok. Visual check is not enough. Exchange that plug wire for another temporarily, and see if it transfers the problem, - if so - bingo! and replace the wire. In fact, replace the whole set. If no transfer, replace the plug. If it fails immediately, suspect the rotor or dist cap (only superman can see an open break inside the cap) . If it fails after several hours, suspect oil fouling. It can have good compression and still leak around the valve guides.
Tim S
04-13-1999 19:10:55
I have a 600 that did the same thing, it would foul 2 plugs. I finally pulled the distubtor out and checked it, i found worn bushings. Changed dist. with another 600 and it runs fine. So check the dist. shaft for looseness. good luck. Tim S.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin
... [Read Article]
Latest Ad:
Looking for a John Deere 50, 520 or 530 in good shape and preferably with power steering and three point. May be interested in a 620 or 630. Thank you.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
