Tracy Brown
I bought a non running 600 a while back. Been setting a couple of years. Got it started pretty easy but the oil pressure is around 60-70 psi. It also was pushing oil out at the spin on filter. I installed a new filter and tightened it with a wrench (usually only good hand tight). I thought it might have spun a bearing and blocked off an oil passage but the engine sounds fine and the new (tightened ) oil filter does not leak. I ran it long enough that a spun bearing should have shown up. What do you good folks think? This tractor is pretty rough around the edges and bad tires so I plan to part it out but I don't want to sell someone a ??? Engine. Engine temp seems fine also.
