I just leased 10 acres for crop production. I know I can do just about all I need with my 2000, but is it too fast to plant with? Or run a tiller? Thanks
Re: Is my 1969 ford 2000 too fast for a water wheel planter? in reply to teddythegreek, 07-07-2016 23:12:05
The shifter in your picture shows that your transmission is a straight 4 speed with no hi/low, so it would be too fast to run a rototiller except in the softest of soils. I'm not sure what kinds of ground speeds the water wheel planter needs, but if you're concerned about being too fast then that tractor probably is too fast.
I ran a 6 foot tiller behind my 3000, 4 speed with hi/low and it was just on the verge of being too fast at 540 PTO. It worked but would have been better if I had one more gear. In a few places I had to feather the clutch to really let the tiller do it's job.
Re: Is my 1969 ford 2000 too fast for a water wheel planter? in reply to steve19438, 07-08-2016 06:19:33
That be it.
Once a common sight here in (once) tobacco country.
Once commonly called a tobacco setter but more accurately called a trans-planter as it was used to plant growing plants, hence the water/chemical tank.
Today's Featured Article - Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
Latest Ad:
need 3 point arms (with the ball) especially need the
[More Ads]
