Company Logo Shop Now
Order Ford 3000 Parts Online
Ford 3000 158 gas crankshaft - Out of Stock?
jchewie
07-07-2016 04:55:35
I have a 1973 Ford 3000 3 cylinder 158 ci gas engine totally apart. Everyone I have talked to says new 3.8" stroke crankshafts are at least a few months out. Used cranks seem to be significantly more expensive than new.
Does anyone have a source?
Out of curiosity, could I put a 4.2" stroke crank in it with matching rods and pistons and turn it into a 172 ci?
Thanks!
Destroked 450
07-08-2016 06:31:47
 Re: Ford 3000 158 gas crankshaft - Out of Stock? in reply to jchewie, 07-07-2016 04:55:35
3600 had a 175 gas engine, good to know.
Wasn't sure about the -600 series, all my books are for the older -000 series that I own.
jchewie
07-07-2016 13:04:04
Email sent, thanks.
Ultradog MN
07-07-2016 10:27:16
Where are you located?
I have one, maybe 2 of them here.
In the Twin Cities, MN
But shipping can be a deal killer.
And yes, if you take the 4.2 crank out of a 3000/3600 diesel and use the gas pistons from a 3600 you will have a match. Gain a slight bump in HP too.
My email should be open.
Sean in PA
07-07-2016 09:23:29
I have a reference that shows the later 3600 having a 175 gas engine.
Destroked 450
07-07-2016 06:31:20
Yes it can be done, my book doesn't show a 175 gas engine, only diesels, but you can use three of the pistons for a early 5000 233 gas engine that has the same bore and stroke (4.2x4.2) as the three cylinder 175.
It may require a rebalance.
Latest Ad: Looking for two coulters and mounting brackets for a JI Case centennial plow [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
