5610 adding another set of remotes
draftx
I need to add another set of remotes. I want to put on a loader and sometimes run a baler with 4 lines. 2 for hyd tie. Any advice would be appreciated.
I have a 6610 that I added a loader remote for.
How many do you have know, and how many are you adding?
I have a pair, 2 hoses go in them. I want to add another pair. Can the loader be plumbed a different way so I don't have to use the remotes on the back?
I plumbed my loader direct, it requires a CCLS control valve and shuttle for the sense line.
It isn't cheap.
I spent about a grand on it, could save money if you can find a surplus valve.
I posted pictures on the Ford forum about a year ago.
Get a 20 GPM closed center load sensing (CCLS) control valve, I got a prince with a joystick kit.
Get a shuttle valve for the sense line.
Tee into the line on top of the transmission for the supply.
Tee into the small sense line on top of the transmission with a shuttle T.
Others know about doing this too.
