Company Logo Shop Now
Order Ford 3400 Parts Online
1969 Ford 3400 + 730/19-425 loader
neighborBOB
04-12-2016 04:44:38
third party image
third party image
Hi Folks
I asked about 2 months ago about parts for connecting a Ford 730/19-425 to a 1969 Ford 3400 Agricultural tractor.
I posted some pictures in regards to how the shaft from the engine to the hydraulic pump might look.
I've got the pulley adapter from the motor side off now and it looks like the picture I've posted.
The 4 bolt adapter is not what I expected. I expected a splined hole and not something that was pressed.
So my question is what is part# 16 in the photo attached?
PS be gentle, I this is my first tractor :)
Hobo,NC
04-14-2016 05:02:19
 Re: 1969 Ford 3400 + 730/19-425 loader in reply to neighborBOB, 04-12-2016 04:44:38
Its possible its threaded in with left hand threads.
neighborBOB
04-14-2016 04:53:48
My best guess (at least until I go to this shop) is that I need:
http://www.link_disallowed/ABC1812-front-hydraulic-pump-drive-hub-adapter
which is all of 16,17,18 in the photo I have.
thanks all, will update the forum once I know
Bob
gears
04-12-2016 06:46:52
hey Bob, I've got a 4 bolt splined flange hub from my 3400 setup (I went with a chain coupler union on the outboard side). I could save you CNH prices.
I can also shoot some pics (I made mine match the 776 loader if you look up the parts diagram on the CNH website).
neighborBOB
04-12-2016 07:10:03
 Re: 1969 Ford 3400 + 730/19-425 loader in reply to gears, 04-12-2016 06:46:52
Hi Gears
I'd appreciate photos if you have them.
If you are selling parts, I'd probably be interested.
thanks
bob
nboboloo@yahoo.com
crawlerjohn
04-12-2016 06:24:05
3400 should have had a splined shaft. Not uncommon to find stripped splines and the shaft welded to the adapter. That makes disassembly difficult without replacing all parts. Not uncommon for the splines to be loose and rattle at this age. Yours might have had a previous makeshift repair. John
neighborBOB
04-12-2016 06:33:05
 Re: 1969 Ford 3400 + 730/19-425 loader in reply to crawlerjohn, 04-12-2016 06:24:05
My guess (knowing that the original owner was a large municipality in my area, who probably had a fleet of tractors), is that this is some non-Ford part (although it has the industrial yellow paint on it).
definitely not splined from what I can see (although I can get it on a press, pop it out and be certain).
thanks
bob
neighborBOB
04-12-2016 04:56:09
third party image
what it looked like previous to removal
crawlerjohn
04-12-2016 06:36:33
 Re: 1969 Ford 3400 + 730/19-425 loader in reply to neighborBOB, 04-12-2016 04:56:09
Original setup for 3400
neighborBOB
04-12-2016 04:46:01
third party image
photo with parts diagram
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
Latest Ad: Needing good 70 series fenders. No rust or dents preferred. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
