Ford Tractors Discussion Forum |
NAA Hydraulic Lift
Author |
[Modern View] |
waynemo
03-31-2016 17:58:46
I got the lift cover off now and found nothing bent or twisted but the linkage is pretty sloppy due to wear I guess. I did see about .030 in. wear on the follower pin and more importantly, I found the pin was riding only half way on the cam surface causing that half of the cam surface to be worn over .060 in. I then cut a 5/16 drill bit about 3/16 in. longer than the original pin and pressed that into place so that it now extends across the whole width of the cam surface. I had replaced the original pin several years ago and did not notice the cam wear. I will bet this alone will cause my lift to go all the way up,(my only problem) something is telling the control to stop pressurizing the piston and I bet it is these worn parts. The two linkage adjustments are another matter! I have 2 ITT manuals and the one shows a plate over the valve to measure from, and the other manual shows the plate was dropped in the newer models. In any case, the control rod is way too far out and I am afraid to make the adjustments and the control valve turnbuckle would run out of thread before it met the spec. in either draft or position setting. For instance, the spec. is 3/16 in. in draft and it is running about 1/2 in. On position setting, the spec. is 1/4 in. and it measures about 5/8 in.
Chilidawg
04-02-2016 13:13:37
Re: NAA Hydraulic Lift in reply to waynemo, 03-31-2016 17:58:46
I downloaded the PDF referenced by Ozlander. It looks to be useful when I get to that stage of my project. I gather from Zane Sherman's (I think) site that the hydraulic systems between the NAA and the hundred series tractors are very similar.
WayneMo
04-02-2016 10:14:01
Thanks for the web site, it is the best thing I have seen regarding how to adjust the hydraulic system..........
Ozlander
04-01-2016 19:40:50
N tractor club dot com has a pdf that's good.
NAA-Hyd-Ctrl-Adjustment.pdf
Sean in PA
04-01-2016 05:09:36
The original pin was not long enough to cover the entire width of the cam surface. When the cam gets worn you should add metal back to the worn part with a welder and then grind it smooth to match the curve of the non-worn section and continue to use the correct original length pin. If you simply use a longer pin to ride on the non-worn section then that area will wear down as well and you won't know how much you have to build it up once it starts having problems again.
waynemo
04-01-2016 07:14:04
Re: NAA Hydraulic Lift in reply to Sean in PA, 04-01-2016 05:09:36
Yes, the longer pin will cause the cam to wear eventually especially since it rides on a smaller unworn section. I don't want to take all the linkage apart since I am afraid I will cause other problems! I sure do not understand why the two adjustments recommended in the ITT manual are so far off. There again, I am afraid to monkey with them. The adjustment in the draft setting is easy to make but the adjustment in the position setting is extremely difficult to make due to the tightness of the adjusting bolt arrangement. I bet that if I took out all the linkages, I would find several really worn parts.
BBq-Bob
04-01-2016 02:44:03
I ran into the same problem. I made a longer plunger rod on my lathe out of some mild steel 7/16th hex stock tapped 1/4-28. I believe I added about .375 to the length of the hexagonal portion of the rod. It worked well.
dmbinva
03-31-2016 18:36:38
I have lengthened that rod to get it close, it does not have to be dead on, but the closer the better
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
Latest Ad:
need 3 point arms (with the ball) especially need the
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
