Company Logo Shop Now
Order Ford 5000 Parts Online
5000 Ford
1070sid
03-19-2016 18:20:18
Guys I have a friend that has a 1970 5000 Ford high crop. Does it have to be split to repair the pto. The clutches are slipping. Thanks.
sotxbill
03-20-2016 08:48:24
 Re: 5000 Ford in reply to 1070sid, 03-19-2016 18:20:18
Ifyou go in, the pto housing will probably be worn where it rides in the support housing and will have grooves worn where the sealing rings ride. As others said, sometimes a new pump will help if its worn out.
Stevob671
03-20-2016 06:14:04
Double check the hydraulic system as that is what engages the pto clutch, ours had a pump or bad line- I can't remember which but it caused very slow engagement and/or slipping.
Shaun Wallace
03-19-2016 19:54:01
Can be serviced from the top. Have to pull deck either way. Then pull lift cover. The deck is the most fun to get off.
1070sid
03-19-2016 21:24:23
 Re: 5000 Ford in reply to Shaun Wallace, 03-19-2016 19:54:01
That's what I thought. Thank you very much.
Latest Ad: need 3 point arms (with the ball) especially need the [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
