Company Logo Shop Now
Left rear cylinder head bolt 172
William Fissell
03-09-2016 05:15:59
Hi, All,
the head I had worked fine. I have one bolt that wont tighten. just spins. Is the left rear tapped hole in the block tapped for a larger cylinder head bolt than the rest? All the through holes in the head are the same. The Ford manual makes no mention and the CNH website seems to indicate they are all the same bolts, 7/16-14 x 4
thanks
Bill
William Fissell
03-09-2016 09:47:21
 Re: Left rear cylinder head bolt 172 in reply to William Fissell, 03-09-2016 05:15:59
I'll look again. I removed the head and replaced it with another. I didnt think about the bolts *at all*
all the holes in the head same size. I ended up with ONE bolt too big to fit in the head and ONE hole that the 7-14-4 bolt just spun around in.
So I'll pull the head back off and see whats up. I have to put thread sealant on the bolts that go in the water jacket anyway.
BBq-Bob
03-09-2016 06:35:25
If you haven't removed the bolt yet; it's likely that the bolt was over torqued and snapped, leaving the head portion to spin. This is not so bad because it means you will still have good threads in your block when the remainder of the bolt is removed.
JWA
03-09-2016 06:19:18
All the head bolts are the same size in that block unless it has been tapped oversize.
BBq-Bob
03-09-2016 05:40:45
Sounds like the threads may have stripped out of the hole. May need to drill and tap for next larger size bolt or possibly install a helicoil. Evaluate the condition of the threads you have and take note of the available wall thicknesses.
William Fissell
03-14-2016 07:28:18
 Re: Left rear cylinder head bolt 172 in reply to BBq-Bob, 03-09-2016 05:40:45
Well, the answer was that the hole in the block was tapped for a 1/2 inch bolt. I assume PO did so after stripping or snapping. I looked at the head and drilled the 7/16 out ot 9/16 and put the head on. we'll see what comes.
Today's Featured Article - Recollections of a John Deere GP - by Charlie Cook. I grew up on my dad's 280 acre general farm in Western Michigan. Dad's only tractor when I was very young was the old GP. My first recollection of this tractor was when dad allowed my brother and myself to ride on the tractor with him driving. One of us would sit on the left fender (away from the clutch) and other would sit on the gas tank and hold onto the crankcase breather pipe. ... [Read Article]
Latest Ad: Wanted front suit case weights and rear wheel weights for a 1456 international. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
