7710 Radiator Removal - what's involved ?
Dwayne F
I have a leak in the cooling system somewhere on the bottom of or below the radiator and can't tell where it is, at least without removing the rad. Is it much of a task to remove it ? and is there a known common problem with it ?
Thanks, Dwayne
Oil is not a big issue. That's just the engine oil cooler that's integrated into the rad tank. It will lose a pint or two. Removal of the rad requires removal of the hood, fuel tank, supports, etc. The hydraulic cooler doesn't need to be removed; just dropped forward. Overall removing the rad is not a big job. I would endeavor to find the leak first tho.
Rod
the fuel tank does not have to be taken loose much less off, it is easier if you take the front sheet metal off though
It probably doesn't have to be taken off.... but some things are not worth the fight. If it's empty I'd take it off. You can either support the side rails and remove the front support or try and wiggle it out towards the engine. Take your pick.
Rod
I was hoping I wouldn't have to take the tank out, it's nearly full but I do understand "it's not worth the fight" too. About finding the leak first, it's in such a place as I cannot see where it's coming from..dripping down in the belly of the bolster and off the axle support. Almost seems to be a cracked in the lower hose nipple but I can't verify it. Anyway, thanks for all the input guys, we'll see what tomorrow brings.
Dwayne
Hey Folks, is all the hype about Anti-Freeze for Diesels something to be concerned with, especially in a 25 yr. old motor ?
YES. Use an antifreeze approved for diesel engine use and in these engines use a bottle of DCA4 coolant conditioner for good measure... Cooling system maintenance on a Ford Basildon engine is not something to be neglected or taken lightly.
Rod
(quoted from post at 23:32:06 02/02/16) I was hoping I wouldn't have to take the tank out, it's nearly full but I do understand "it's not worth the fight" too. About finding the leak first, it's in such a place as I cannot see where it's coming from..dripping down in the belly of the bolster and off the axle support. Almost seems to be a cracked in the lower hose nipple but I can't verify it. Anyway, thanks for all the input guys, we'll see what tomorrow brings.
Dwayne
It was a crack in the lower nipple...heated and removed it..cleaned it up and re-soldered it..all is well now...tnx guys...sorry for the late response..Life Happens :)
