I have a flat on a recently purchased 861, on a back tire. I was using it to blade the driveway and noticed water shooting out of the rim. I need to know if I can jack up the tractor with a hydraulic jack under the rear end and then put blocking under the axle to hold it while I fight to get the wheel off. Will it hurt the differential if I jack it up there? Also am I better off removing the 8 lug nuts to remove the tire and wheel or should I remove the nuts at the tread width adjustments and only remove the tire and rim? I'm guessing I'll have to patch or replace the rim. Thank you in advance for any help and encouragement.
