Ford 3400 with 750 backhoe
Kbmwlg1
New User
When i got tractor backhoe was off i need to know where exactly how to hook up all three hydraulic lines thanks in advance
The 2 smaller ones that maybe connected together go to fittings rite at edge of deck. Its late and have to go a ways to see where big one hooks at. I have a 4500 strung out with hoe and loader off plus split in two pieces.
It has one steel pipe on the bottom left of backhoe and one rite under deck on same side and one bigger line connected to right side of backhoe valve and lower pipe on the left bottom goes to right side of the valve on the bottom just below big hose and top left goes to the left side of the backhoe valve then on tractor i have pipe thread going into reservoir and steel pipe to pump and steel pipe to valve for loader ive hooked them up a couple of ways with no luck only being able to run only one piece per hose routing.also anyone know where to buy a front hydraulic pump center section thanks
(quoted from post at 21:41:24 01/11/16) The 2 smaller ones that maybe connected together go to fittings rite at edge of deck. Its late and have to go a ways to see where big one hooks at. I have a 4500 strung out with hoe and loader off plus split in two pieces.
Shaun Do you have a reversable seat for that 4500 ford that you will sell? I need one.
