Ford Tractors Discussion Forum |
5600 ford powwr steering?
Author |
[Modern View] |
pt756
01-02-2016 16:41:17
we have a 5600 ford have had trouble with power steering leaking out the top took it apart mechanic showed us how to fix it once used a repair kit with a speedy sleeve, installed that and put new sleeve over it, first time did not work second time worked better, however he noticed a Teflon seal also said must be a different type well looked a all states tractor for a replacement their replacement looks different probably a more common type,anybody familiar with that steering set up, would surely replace with one of their rebuilds if a person knew it would bolt on where the speedy sleeve went on that shaft is kind of worn any help is appreciated,
pt756
01-03-2016 15:28:52
Re: 5600 ford powwr steering? in reply to pt756, 01-02-2016 16:41:17
sll I can say is that our pump does not look like the rebuilt pumps that all states ag offers, don't really know much about these things thanks for replies
Sean in PA
01-03-2016 11:47:09
Power steering pump on a 5600 (utility) or 5700 (row crop) should both be the one with the integrated reservoir that is driven off of a gear at the front of the engine on the left side.
showcrop
01-03-2016 10:39:36
So then it has the pump on the left run off the Fan belt?
showcrop
01-02-2016 19:31:32
It sounds like yours is the high platform model, so it probably has the steering motor/valve under the steering wheel. Those have very close tolerances, but if a speedi sleeve fixed it before perhaps it could again. Speedi sleeves are very thin and under dusty conditions it could have worn through.
pt756
01-03-2016 07:59:28
Re: 5600 ford powwr steering? in reply to showcrop, 01-02-2016 19:31:32
the 5600 is a utility model guy just said it is different because of the Teflon parts in it
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Oliver 4340 Plow Setup - by ShepFL. How to properly setup your Oliver 4340 plow plus many tips and pointers that may apply to many other brands of plows as well.
... [Read Article]
Latest Ad:
Would like to find hay table for a John Deere 700 or 750 grinder mixer
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
