Hi Folks,
I a have a 1971 Ford 4500 3 cyl. diesel tractor with a Type K 6/4 manual reversing transmission (no PTO). I am in the process of replacing the clutch disc, pressure plate and input shaft seal.
I noticed that the transmission input shaft has a 1/8" - 3/16" movement (wiggle) from side to side as it comes out of the transmission. Is this expected? I assume that once the engine is reinstalled the tip of the input shaft will be riding in the bearing or bushing in the tail end of the crankshaft and won't be a concern. Is that correct?
Thanks,
Ray
Thanks,
Ray
