Ford 661 body bumpers
I have a book on this, but no mention of where these rubber bumpers are supposed to go. I found one on the floor after i had removed the hood, there were supposed to be 2. I think there is supposed to be some on the grill too? i purchased new ones, and i'm not sure where they go... help? again,, :)
Also,, the right side hood was spot welded to the vertical panel, the left side was not, i am not sure if this was stock or not,,, thanks in advance.
(quoted from post at 10:46:59 11/13/15) Also,, the right side hood was spot welded to the vertical panel, the left side was not, i am not sure if this was stock or not,,, thanks in advance.
There are two bumpers that go between the hood and top of the radiator.
(quoted from post at 17:47:49 11/13/15) Ah hah, that makes sense, thank you
Also just checked there are 4 total on the grill on my 640. Two on either side where it meets the hood. Spaced roughly 3" down from the latch on top and two inches up from bottom of the "slats" in the grill
