Company Logo Shop Now
Ford 555a transmission grinding
sparky7
08-15-2015 11:38:49
So this backhoe is not moving and there is a noise like a whirring grinding coming from the torque converter area. The noise is intermittent and something is clearly broken but im wonding what it could be?
Just a bad torque converter? bad flywheel? broken input shaft? broken converter bolts? snapped crankshaft?
I understand there is no way to know until the tractor is split, but if anyone has a best guess im all ears.
Thanks, Sam
This post was edited by sparky7 at 11:40:41 08/15/15.
sparky7
09-16-2015 13:55:19
 Re: Ford 555a transmission grinding in reply to sparky7, 08-15-2015 11:38:49
Well i split the ford, and the drive plate is available but i cannot find the alignment tool for sale anywhere.
Does anyone know where i could find it? Torque converter alignment tool No. 11890
sparky7
08-15-2015 15:13:55
Yes i hope that is it! Its only 120 dollars :) Luckily i have my trusty oliver 550 loader to help me split the backhoe
RickB
08-15-2015 11:50:43
My vote goes to a broken flex plate. (Between flywheel & torque converter)
juniur
08-15-2015 13:46:13
 Re: Ford 555a transmission grinding in reply to RickB, 08-15-2015 11:50:43
I second what rickb said I have seen it several times. And yes you have to split the tractor to fix it.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: Shaw due all tractor [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
