Company Logo Shop Now
Vane Pump Replacement to Piston Pump
buster1410
08-04-2015 16:21:05
Good evening all, My 1955 860 has the old Vicker vane pump and it is now leaking hydraulic fluid badly, so I have decided to replace it with a rebuilt piston pump. I was wondering how extensive the process will be of replacing the vane pump with the piston pump and what difficulties/problems should I expect with the replacement process?
scott pa
08-04-2015 18:21:44
 Re: Vane Pump Replacement to Piston Pump in reply to buster1410, 08-04-2015 16:21:05
Also may have to change engine oil pressure line and elbow to clear pump or else the pump housing will break when installing on engine.
buster1410
08-04-2015 18:44:44
 Re: Vane Pump Replacement to Piston Pump in reply to scott pa, 08-04-2015 18:21:44
Will I have to take the engine oil pressure line off in order to get the new pump on or will I have to change the angle of the line and elbow so it clears the pump housing?
soundguy
08-04-2015 16:35:42
Vane to piston?
Need some wrenches, remove some bolts, catch some oil, swap pumps, plumbing manifold, orings, bolt back, replace oil, maybee bleed.
buster1410
08-04-2015 16:48:59
 Re: Vane Pump Replacement to Piston Pump in reply to soundguy, 08-04-2015 16:35:42
Thanks soundguy, it sounds like a pretty simple process once I get all the parts.
Today's Featured Article - The Niagra View Mobile - Powered by a 1959 Ford Tractor - by Mark Massey. In 1959 the Niagara Frontier Transit Inc. of Buffalo, New York designed and built six Viewmobiles for the Niagara Frontier Sightseeing Inc. for use as a sightseeing ride at the Niagara Falls State Park, Niagara Falls, New York, powered by a 1959 Ford 611 Tractor. ... [Read Article]
Latest Ad: Hiniker 1300 rear window frame looking for one closer to Iowa the better [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
