Company Logo Shop Now
Introduction and a ?
Pivo and Kolache
07-08-2015 03:59:19
Hi all, longe time listener first time caller. I bought a 6600 with factory cab the other day and is my first experience with this series of tractor with a cab. I've been noticing it runs a touch on the warm side and its a bear trying to get to the radiator to blow it out with the shroud on the back side and the condenser (which does not swing out) on the front. Aside from removing the condenser and nose cone is there a good way that you fellas access the radiator to blow it out?
sotxbill
07-08-2015 05:56:36
 Re: Introduction and a ? in reply to Pivo and Kolache, 07-08-2015 03:59:19
The lines come from one side to allow you to slide it over towards the lines.. unless someone has changed it. should move enough to allow access to most. Be careful to not bend the radiator fins when cleaning or you will have more problems so keep the pressure low on the water or air that you are using. I find it takes several passes to slowly clean out years of mud and chaff. Each time more will come out.
kub6040
07-08-2015 04:37:22
The only way to Truly clean the radiator is to remove the rest and clean one at a time .
Pivo and Kolache
07-08-2015 05:03:26
 Re: Introduction and a ? in reply to kub6040, 07-08-2015 04:37:22
I was afraid of that, I have it apart now to replace the hyd lines to the cooler and did just as you described, but I'm afraid this is going to be an ongoing problem for me as I bought this tractor to shred and use in the hay field. Suppose il look into possibly making the condenser hinged to swing out.....has anyone attempted this?
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
Latest Ad: Farmall A. A complete restoration of a 1939 Farmall A. Parade ready. Whole motor has been went through. New tires. Everything factory except the stack. Crank start only. OBO [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
