Company Logo Shop Now
Order Ford 3000 Parts Online
3000 gas with holley carb running rich after new fuel pump
Bikerider
07-03-2015 14:21:04
Looking for some expert opinions here. I just put a new fuel pump on this tractor. After getting it all back together and starting it, it started to leak gas from a short rubber gas line by the carb. Today I replaced the rubber gas line. Now the tractor is running rough and very rich. Black smoke and all. The tractor ran like a top before I replaced the fuel pump. My guess, the new pump has more pressure and the carb is flooding. Needs to be rebuilt? Anyone have any ideas?
sotxbill
07-03-2015 19:23:18
 Re: 3000 gas with holley carb running rich after new fuel pu in reply to Bikerider, 07-03-2015 14:21:04
yes...maybe goop on needle valve and float. goop can cause float to hang up. or bad seal on needle valve. check for smooth operation of float but beware that with carb together the float can rub the side of the lower housing and still hang.
Bikerider
07-06-2015 08:20:30
 Re: 3000 gas with holley carb running rich after new fuel pu in reply to sotxbill, 07-03-2015 19:23:18
found problem to be new fuel pump is delivering way higher gas pressure to the carb. Should be 2 pounds or less and this one id over 7 pounds. Will have to install a fuel pressure regulator.
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos ... [Read Article]
Latest Ad: Armstrong 11.2x24 4 ply new never run,mounted on Allis B or C rim [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
