2ndNewcomer
New User
I have a backhoe model 1168 power digger on a Ford tractor and the front shaft to the pump has slid forward and stripped the teeth. Is there any kind of manual or website with exploded views to help with repair?
Not sure what happened but was a cold morning, snow on the ground, and was gonna use to help drag some of my junk I was delivering away from the road as it was too muddy to try and bring a rollback in there and the shaft just slipped forward and started grinding metal.
I'll get around to pulling it out when I can but must be some sort of retaining clip that failed and a parts guide might give me some clues. I think it's a 641 tractor, I got #29NN6015B from the right side of the engine and #310835 from the right side of transmission.
There is a dash plate with a # on it and I guess the original owner etc. I need the shaft fixed and a breather tube and she will be ready to work. At least for my little place not full-time construction. A little slop in the bushings so I need to fix them too. Solid little tractor though. Any help is certainly appreciated.
