Company Logo Shop Now
Order Ford 800 Parts Online
Ford 800
themuleskinner
03-06-2015 07:29:09
Going to look at a ford 800 that is in very good condition. He is asking $3500. Is that too much ?
themuleskinner
03-10-2015 19:37:27
 Re: Ford 800 in reply to themuleskinner, 03-06-2015 07:29:09
third party image
Well thanks for everyones input but I came across this deal and bought it....Long 460 w/loader, woodsplitter,backblade ,scoop and alot of extra parts. Runs great everything works as it should. Power steering and 4x4 with cat 2 3 point
themuleskinner
03-07-2015 05:21:31
third party image
I can get either of these for $3500 for just tractor. Which one is the better machine in your opinion ? And thanks for all the input ...
Fordfarmer
03-07-2015 06:48:11
 Re: Ford 800 in reply to themuleskinner, 03-07-2015 05:21:31
I have a significant anti-JD bias, so of course I'd say the Ford is better. But even looking beyond that, I see worn tires on the JD, and it seems like the 1010 is one that even the guys who bleed green say to avoid.
tom new jersey
03-06-2015 17:05:25
Two things to think about, 850 no live pto and I believe no power steering. Just my 2 cents.
Kirk-NJ
03-06-2015 22:33:14
 Re: Ford 800 in reply to tom new jersey, 03-06-2015 17:05:25
Hello Tom,
Power steering was available in 1957 so it is possible to have PS in an 850. My '57 640 has ps.
Kirk
jimmyjack
03-06-2015 15:21:53
Unless it has surprises, it is good as far as Im concerned.
64frd4000ind
03-06-2015 12:07:23
I don't think anyone would laugh at that price, its a nice looking tractor, and with the new parts on it, should be good to go.
Make sure it holds good oil pressure though, if it doesn't, there is a reason he's getting rid of it.
I personally would probably try to get him to meet you somewhere in the middle for the whole package.
And definitly find out about that exhaust, I would change that to either a verticle with rain cap or back to the horizontal that runs under the tractor.
themuleskinner
03-06-2015 12:00:20
third party image
third party image
third party image
No smoke no leaks runs great solid stiff hydraulics
themuleskinner
03-06-2015 11:53:58
third party image
Here it is
steve Brussell
03-06-2015 11:53:26
That is the one on Craigslist Binghamton, NY, correct? That is an odd exhaust setup on it. It appears the exhaust pipe is pointed forward. I would ask about that.
esbrian
03-06-2015 11:37:34
That sounds a little steep for this area, but as 64frd4000ind noted, it depends a lot on how you define "good" or "very good" condition.
I don't see a lot of Fords for sale in this area that aren't Ns, and that may affect the prices people are able to get for them.
themuleskinner
03-06-2015 11:34:24
I have pics but cant figure out how to post them
themuleskinner
03-06-2015 10:09:38
He want 4300 with double ring chains and heavy duty ford backblade
64frd4000ind
03-06-2015 07:46:32
Depends on where you live, and what 'good' condition means.
New Rear Tires can run close to $1000, fronts are cheaper.
A working loader in good shape can run anywhere from $500-$1500 depending on if its a trip bucket or a 725 loader.
Again location matters, things are cheaper here in Southern Illinois than in Texas.
In my area a Diesel will bring $500-$1000 more than a gas tractor.
In my area a Tricycle front end will subtract that same amount.
Paint, a GOOD new paint job can add $1000 around here, while a BAD brushed on job can Subtract $500 or more. While Original Sheet metal with just surface rust and no holes can be almost as desirable as a fresh paint job. Depending on the model of tractor.
Around here If it has a loader, runs, no smoke, original patina, no major rust, gas engine, with decent but not brand new tires, with a wide front end. I have seen them anywhere from $2500-$3500, Diesels up to around $4000, and fresh paint usually means you don't want to ask.
themuleskinner
03-06-2015 07:31:12
I mean 850
old
03-06-2015 10:11:06
 Re: Ford 800 in reply to themuleskinner, 03-06-2015 07:31:12
First off your correct both places. 800 is the series and 850 is the model which has a 5 speed and no live PTO. That said back in the early 80s we payer $3250 for an 841S with a loader and a plow. So may well be a good price if the tires are good and it runs well and does not smoke
Fordfarmer
03-06-2015 07:48:36
Pricing tends to be regional. $3500 would get you a very nice 850 around here (n/w WI)...in fact, most 860's don't bring more than that. It should have new (or very good) tires at that price.
themuleskinner
03-06-2015 12:55:49
 Re: Ford 800 in reply to Fordfarmer, 03-06-2015 07:48:36
Tires are like new and it comes with new double ring chains and ford deerborn backblade...he wants $4300.....what do you think
Fordfarmer
03-06-2015 20:17:38
 Re: Ford 800 in reply to themuleskinner, 03-06-2015 12:55:49
Quite a difference with or without the chains and blade. Tire chains can be had for $100-150 at auctions...less in the off season. The blade looks decent, but is not what I'd call "heavy duty". I'd give maybe $300 for the blade and chains. I don't like that exhaust, either..but I've seen worse. Any steel seat, Rest-O-Ride or otherwise, would get replaced on my tractor. Lights...probably a 12V conversion and he didn't upgrade the lights. Maybe he still has them somewhere. Not a big issue to me. I'd say $3500-$3800 for the package. Offer $3500, with cash in your hand. Worst he can say is no...
WayneIA
03-06-2015 14:01:14
What do I think!! It has no lights, no rest-o-ride seat, no drawbar, 9N/2N steering wheel. Better through in the chains and the blade and maybe, $3500 around here
Latest Ad: John Deere A 1945 styled [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
