correct color ford 950?
1955 950
There seems to be alot of confusion on the gray on these tractors. Does this look rite. Here is my 1955 950
Here's a shot of my working 950 I used ford paint on the tin. It's basically the same as the 8n. I believe the later 01 series used the liker gray. The tractor in your photo looks fine. You can go to a tractor show and there will be 10 8n's there all with "correct" color and there will be 10 different shades of grey.
Kirk
You see a lot of them painted the later lighter gray. Like Kirk says, 8N up through the X00s are all the medium gray. it changed in 58. The best way to get a good match to original is digitally by taking the lower dash to the automotive paint store and have them digitally analyze the unmolested paint from the inside of the piece.
Nice looking tractor. However, unless it's a quirk of photography, the red appears to be the vermillion red of the 01 series. The red should be the color of Kirk's or all Fords from the 8N through the 00 series.
Basically, yes. I have seen both vertical and underslung exhausts on the 541 and 2000 offsets. Pipe size on my 950 is different for the 172 to your 134 engine in the offset.
Kirk
(quoted from post at 09:28:39 02/14/15) Is the vermillon red your talking about the orange red of x01
series. It is not that orange red color.
Your red does look a little towards the Orange red of the XX1s. The earlier red is the shade usually referred to as vermillion.
There is no confusion about the colors on these or any other FORD tractors there is only one color for them , the problem is that NO ONE bothers to get the CORRECT PAINT CODES for them from FORD and instead mixes the wrong color and then says their color is correct when it is not . Pictures do not show the true color but it still looks wrong , it does look like 01 series colors as others have said . 100 series ORIGINAL FORD PAINT CODES are as follows M-2822-SE for the VERMILION COLOR and M-2888-SE for the GRAY COLOR , NAPA , PPG , SHERWIM-WILLIAMS , DITZLER should all be able to CROSS FORD CODES TO GET formula mixes TO MAKE THE PAINT . Thanks Tony
M-2888-SE is the 9N-2N GRAY COLOR , M-13243 is the CORRECT GRAY COLOR for the 100 series tractors . M1J-956-SE2 is the RED COLOR for the 01 series tractors , M1J-957-SE2 is the GRAY COLOR for the 01 series tractors . Thanks Tony
We go to the 'Antique Power Days' here in Salem, IL every year, and they line up 'like' tractors in rows, so that you can go to one area to look at what you like and talk to the folks who own them.
Every year there will be a dozen or so Fords lined up, all with slightly different shades of red/grey and each person saying theirs is 'correct' and using 'factory codes'... It can and does cause arguments and even fights...
IMHO as long as you are happy with how it turned out, and its close enough to what 'should' have been original for your taste, then its perfect, especially for a tractor thats 50+ years old.
And when you remember that they can't use the same pigments or even paint base they did in the 50's because of EPA regulations... so no matter how close it is, it never would be the same...
Something else to know about the digital paint readers, you can go to two different Sherman Williams(Insert your paint store here, doesn't matter) and if they have different overhead lighting, or even a light bulb out near the machine, then you will end up with two different paint colors. And if they read the chip 2 or 3 times its likely to come up a bit different each time.
Also, air alone will change a paint color of the years, not so much as the other elements, but just being open to air in general will not necessarily make it fade, but will change the colors, remember there were no 'clear coats' back when our tractors were made to seal in the paint color.
I have even seen a pink case tractor, donated to the relay for life (breast cancer) cause, and it looked awesome, different, but awesome.
(quoted from post at 07:34:42 02/16/15) M-2888-SE is the 9N-2N GRAY COLOR , M-13243 is the CORRECT GRAY COLOR for the 100 series tractors . M1J-956-SE2 is the RED COLOR for the 01 series tractors , M1J-957-SE2 is the GRAY COLOR for the 01 series tractors . Thanks Tony
Well, since the shade varied by paint batch, some how we need a whole batch of different codes so that we can narrow it down to the month that the tractor that we drove as a kid was manufactured on. THEN we need to find a way to get the paint guy at the paint jobber to agree to do it by code instead of using his high tech digital reader. I'm happy to have my '57 close to medium factory gray for March 1957, as matched from the underside of the hood and not 58 to 63 gray or 64 on light gray. The gray of my '59 looks very nice contrasting against the medium gray of my '57, instead of appearing the same.
Hello Keith , You are correct about the pigments being different I forgot all about the removal of lead from paint pigments alone . Thanks Tony
