Company Logo Shop Now
Generator Warning Light
64frd4000ind
01-20-2015 17:32:43
Got a new lens, but it didn't come with a bulb or socket, this a part store item or is it something special I'm looking for?
This post was edited by 64frd4000ind at 17:33:03 01/20/15.
64frd4000ind
01-21-2015 19:59:12
 Re: Generator Warning Light in reply to 64frd4000ind, 01-20-2015 17:32:43
No spade connector on my alternator. Just the battery lug.
sotxbill
01-22-2015 16:23:59
 Re: Generator Warning Light in reply to 64frd4000ind, 01-21-2015 19:59:12
Not a rubber plug next to the battery lug that covers the spade lugs?
64frd4000ind
01-21-2015 11:05:20
Like I said, tractor has the 12v conversion done to it, so not really worried about 'original' just want functional here.
sotxbill
01-21-2015 17:26:08
 Re: Generator Warning Light in reply to 64frd4000ind, 01-21-2015 11:05:20
if the alt has a big battery lug, and then two spade terminals beside the battery lug......
run a wire from the spade lug closest to the battery lug back to a "two wire light socket,,,, to one of the wires and then the other wire on the socket going to the "on" side of the ignition switch.
The two wire socket is still availible for a ge53 bulb, but the connector will not let the bulb go to ground, but too the 2nd wire. Often refered to as a oil pressure socket or a generator light socket for older cars.. If you dont mind changing to a t10 bulb, you can get the sockets much cheaper.
http://www.ebay.com/itm/1955-1956-1957-CHEVY-DASH-INSTRUMENT-PANEL-GENERATOR-OR-OIL-LIGHT-SOCKET-4-/251800754676?pt=Vintage_Car_Truck_Parts_Accessories&hash=item3aa07e99f4&vxp=mtr
64frd4000ind
01-21-2015 11:04:30
On a side note, my tractor has had a 12v conversion done to it, and has a Single Wire Alternator on it.
How would I make this light come on if the alternator stops charging?
My thoughts were to find an automotive relay that is Normally closed that will open when it has 12vdc applied.
sotxbill
01-21-2015 07:23:12
Alway find good stuff on ebay.. these will work on the newer instrument panels,.
http://www.ebay.com/itm/Volvo-1800-P1800-1800S-P1800S-Smiths-Dash-Gauge-Light-Sockets-Bulbs-Nice-/171642577080?pt=Vintage_Car_Truck_Parts_Accessories&hash=item27f6b1e0b8&vxp=mtr
John in La
01-21-2015 06:20:36
The correct bulb can be bought at any parts store.
On the other hand; The bulb socket is part of the wiring harness and is no longer serviced by New Holland.
The only place you can get the correct bulb socket (that I know of) is to cut it out of the wiring of a junk yard tractor.
64frd4000ind
01-20-2015 18:15:07
All I can find on the CNH diagram is #2 and thats just the lens and nut, doesn't show the actual bulb assembly.
Dean
01-21-2015 06:04:38
 Re: Generator Warning Light in reply to 64frd4000ind, 01-20-2015 18:15:07
IIRC (haven't checked), the lamp assembly is part of the wiring harness.
Again, probably NLS.
Dean
soundguy
01-20-2015 17:57:20
If you just need it to work, then something can be rigged up with a 168 type lamp. Lense will look correct, but if the sphincter police look under the dash you will loose originality points... GottA watch those annually retentive originality in specters ya know!
Dean
01-20-2015 17:44:23
CNH only.
Probably NLS.
Dean
Latest Ad: John Deere A 1945 styled [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
