Company Logo Shop Now
Order Ford 601 Parts Online
My 601 is had to start after it is ran for a while
farmer3333
01-17-2015 17:53:44
my 601 is very hard to start after it has been running for a while I have to choke it very heavy to get it to start and some times it just stops running this is something that just started happening. I have made sure the gas flow to the carbarater and the carb is clean. I have changed the points, the distributor cap and the rotar buttons. Where do I go next? Please advise. Thanks Alex
William Fissell
01-18-2015 12:15:03
 Re: My 601 is had to start after it is ran for a while in reply to farmer3333, 01-17-2015 17:53:44
Assuming its fuel as you say the spark is good
How long after starting does it get in trouble? 1 minute? 20 minutes?
During that window of time when it is running, can you load the engine, or will it stall?
My Jube did this very badly and it was a clogged filter in the tank, as others have said.
Does it do it on first starting in the morning, or do you have to run it a few hours and then it acts up?
did anything change such that the fuel line might be now in contact with the manifold and causing boiling?
soundguy
01-17-2015 17:56:26
Check more, change less.
At moment of hard start.. what's spark like?
If good, move to air/fuel/compression side of coin
farmer3333
01-17-2015 18:04:10
 Re: My 601 is had to start after it is ran for a while in reply to soundguy, 01-17-2015 17:56:26
It has good spark but it like it has a hard time drawing the fuel cause the plugs will be dry and I have to put my hand over the carb to get it to draw enough gas to start. It starts great when the engine is cold but after it warms up sometimes it dies out of the blue and then I can't get it started again without choking heavy and putting my hand over the carb...
old
01-17-2015 19:00:43
 Re: My 601 is had to start after it is ran for a while in reply to farmer3333, 01-17-2015 18:04:10
When it dies carefully pull the gas cap off . Listen for a vacuum type sound or a blow out sound. Gas tank vent maybe clogged up and pulling a vacuum which means the carb does not get gas. Or the fuel line maybe going bad and closing off when it gets hot which it does. You can also pull the carb drain plug and make sure you have a good steady gas flow when it dies
soundguy
01-17-2015 18:29:25
If it starts good, runs OK, then stalls and spark is good and plugs are dry, try start fluid, if it takes off immediately, check carb first
Starting good cold likely means compression OK.
PS, might check timing too
kub6040
01-17-2015 18:44:24
 Re: My 601 is had to start after it is ran for a while in reply to soundguy, 01-17-2015 18:29:25
Have you checked valve clearance?? That could change hot to cold .
soundguy
01-17-2015 18:50:52
 Re: My 601 is had to start after it is ran for a while in reply to kub6040, 01-17-2015 18:44:24
I wouldn't expect valve clearance to change suddenly, however if suspect, the dry/wet test will tell some
farmer3333
01-18-2015 17:54:34
 Re: My 601 is had to start after it is ran for a while in reply to soundguy, 01-17-2015 18:50:52
Thanks to everyone for the help. It is much appreciated. I have used a seperate one gallon gas tank to rule out the trash in the tank. Installed a new fuel line and filter with no change to the problem. I was thinking it might be valve clearance but I wasn't sure if that could cause this problem so that will be my next step is to check that. Does anyone know the clearance specs are off the top of your head. The problem starts 20 min to an hour into work. Thanks again for all your input. Also I havent checked the timing yet so will do that as well. Alex
Stevob671
01-18-2015 06:28:02
I'm with OLD on this one...had a Deere lawn tractor do the exact same thing...turned out to be the gas cap vent was plugged. Took a while to figure it out after cleaning carb, replace fuel filter etc...finally unscrewed the gas cap, started right up. Cleaned the vent hole- whala! Besides it cost nothing (except for all the time I had the carb off and so on and the fuel filter). Just loosen the cap and see if it starts.
sotxbill
01-18-2015 07:06:23
 Re: My 601 is had to start after it is ran for a while in reply to Stevob671, 01-18-2015 06:28:02
yelp... or a piece of gunk floating around in the tank.. That stops up the drain and cuts it off... so check the cap and if not drain the tank, remove the drain valve and clean all.
Today's Featured Article - Box Plow Blues - by Tom Schwarz. One of the first implements most tractor owners obtain is the box plow. For very little money, this piece of equipment promises to plow and flatten any hill or vale on your ranch road or farm. At least that's what I thought! As simple as a box plow appears, it can be rather challenging to make work correctly. In our sandy soils of Florida, traction is king. You can never have wide enough tires or heavy enough weights to get all the traction you want unless you own a monster tractor. U ... [Read Article]
Latest Ad: Oliver model 101 1-16 rope trip plow on steel. Includes new share/point and great mouldboard. 300 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
