Company Logo Shop Now
Order Ford 3000 Parts Online
1966 Ford 3000 Hydraulic oil in winter
Bart Ca
01-13-2015 07:40:06
When I start the engine @ 0°F I have to run the engine for 30 ~ 45 minutes warmup to have the hydraulic working. Im do'nt know which oil in the rear end I bough this tractor few month ago from an estate.
Is it correct to use 10W30 engine oil to have tinner oil ? Some Massey-Ferguson owners use 10W30 in diff/trans/hyd sump.
Thanks in advance.
Bart
sotxbill
01-21-2015 14:53:27
 Re: 1966 Ford 3000 Hydraulic oil in winter in reply to Bart Ca, 01-13-2015 07:40:06
your ford is designed for a TRACTOR rated hydraulic fluid.. and not plain hydraulic fluid. Most folks sell a UNIVERSAL TRACTOR HYDRAULIC fluid that meets Ford, New Holland, John Deere, International.. etc etc hence the name ""Universal"" Tractor Hydraulic fluid. UTHF is usually cheaper than a brand name tractor fluid like New Holland, International, 303, Hytrans, John Deere, Kuboto or others. You can buy it a Walmart, Sams, most all autoparts and all hydraulic shops. Sams was less than 50 bucks for 5 gallons last time I checked, Bobcat was $90 bucks for 5 gals of synthetic, so your prices can vary. Bobcats are designed for anti wear (anti friction) additives so your getting a different product. labeled with the AW designation.
Many motor oils can have low friction additives that will cause the wet brakes and pto clutches to slip so a really GOOD motor oil is NOT recommended for wet brakes and wet clutches. Sorry to ruin that thought but back to anti friction additives. A mediocre motor oil would work but does not have the anti foam additives and oring conditioners in it. So again, its NOT recommended.. Please use a Universal Tractor Hydraulic fluid in your transmission, your rearend/hydraulic, and in your power steering reservoir. You will see it meets the ford MC134 spec on the container and that is the fluid Ford/New Holland recommends.
ChrisGuerrero
01-21-2015 13:32:48
Hi Bart CA,
The correct hydraulic fluid for your 1966 Ford 3000 Tractor would be our “Shell Spirax S4 TMX,” which is a premium SAE 10W-30 multi-functional tractor transmission and hydraulic oil.
-The Shell Rotella Team
Texasmark1
01-14-2015 17:00:52
Use transmission/hydraulic universal fluid. The F spec is 134A as I recall. Common sump hyd and diff. Tranny uses same oil. I have the '65 year model. On engine oil use C (compression) rated if diesel. Wally world house brand 15w 40 is a fine dino oil competitively priced. That's what I use in my Fords. In my new tractor of another brand I use Rotella T 5w-40 full syn.
Mark
Mike(NEOhio)
01-13-2015 09:32:22
My 2000 had been failing to lift or chattered and lifted slow at anything below 40 deg. I rebuilt the pump last year. Now it lifts right away at zero.
soundguy
01-13-2015 07:46:01
IMHO, using 10w30 engine oil in a shared common sump as you say some MF users do is a bad idea. 10w30 engine oil is not rated for gear use.
Your common hyds and gear rear sump in your 3000 should use a utf fluid. You can get cold weather utf or even synthetic UTF from many suppliers.
you can also put a mag block heater or 2 on her to help speed things up.
if parked in a shed or garage ( even better ), then even an old trouble lamp with a 120w bulb burnig under the sump can help.
couple all that with a battery trickle charger, a coolant lower hose heater, and an oil pan block heater and she will be much easier to start and bring up to temps and use in arctic weather.
Today's Featured Article - The Niagra View Mobile - Powered by a 1959 Ford Tractor - by Mark Massey. In 1959 the Niagara Frontier Transit Inc. of Buffalo, New York designed and built six Viewmobiles for the Niagara Frontier Sightseeing Inc. for use as a sightseeing ride at the Niagara Falls State Park, Niagara Falls, New York, powered by a 1959 Ford 611 Tractor. ... [Read Article]
Latest Ad: Hiniker 1300 rear window frame looking for one closer to Iowa the better [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
