Company Logo Shop Now
Order Ford 600 Parts Online
3600 engine adjustments
DavidLa
08-20-2014 17:36:59
Got the 3600 oil pressure checked today, cold it was 67 lbs, about 60lbs warmed up. got the oil sensor light to work finally as well- rat chewed the wire. i am going thru the new machine trying to get things tuned up.
I have driven a few 3600s/3000s/4600s the last couple of months shopping for the one i finally bought. I noticed the engines are fairly loud, all of them. not only general noise level, but they all seem to have a type of what sounds like compression knock or something? I am use to hearing my small 3 cyl dexta which is very quiet compared to these bigger 3 cyl"s.
How do you know if the knock is just normal or not?
also
I will be adjusting the valves this weekend, I usually spray my valve cover gasket with high tack and stick it to the cover when replacing. Is it a good idea to use the tacky spray or not?
David G
08-23-2014 19:20:59
 Re: 3600 engine adjustments in reply to DavidLa, 08-20-2014 17:36:59
My 6610 is noisy, but a real solid tractor. Does that have an inline pump? If so make sure and change the oil in it.
Fordfarmer
08-21-2014 07:07:21
No getting around it - 3-cylinder Fords diesels are noisy. The 3000/3600's seem a bit worse than 4000/4600's... to me, anyway. Best advice I can give you in that regard is to make sure you have a good muffler on it. Oval ones tend to be quieter than round ones.
jimont
08-20-2014 17:53:47
I too have a 3600 and that is just normal for those Ford 3clys. I also have a David Brown 880 3 cyl and it is just as noisy as those Fords. I also had a Super Dexta 3cyl and there is no comparison (keep in mind that 152cu/in the Dexta is very comparable to the 152 Perkins in the '35 MF's)
DavidLa
08-20-2014 17:53:44
Also, forgot to mention, the engine has no blow by. thanks
Today's Featured Article - Box Plow Blues - by Tom Schwarz. One of the first implements most tractor owners obtain is the box plow. For very little money, this piece of equipment promises to plow and flatten any hill or vale on your ranch road or farm. At least that's what I thought! As simple as a box plow appears, it can be rather challenging to make work correctly. In our sandy soils of Florida, traction is king. You can never have wide enough tires or heavy enough weights to get all the traction you want unless you own a monster tractor. U ... [Read Article]
Latest Ad: Oliver model 101 1-16 rope trip plow on steel. Includes new share/point and great mouldboard. 300 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
