Old Yeller Ford
New User
Hello all! Have enjoyed reading a bit here and gleaning some of you tractor buffs' knowledge. Appreciate the helpful atmosphere here.
My bro is the gear head of the family but doesn't have Ford tractors so he's a bit stymied by this issue. I know you folks will shine through! I am severely limited (bro says "handicapped") in my knowledge and abilities with these machines.
Ford 3000 gas tractor. In tank filter screen dislodged and allowed some debris to block hole of fitting. Nothing found in glass sediment bulb or when blowing air back through gas line from it. Now assembly replaced (because I snapped off the plastic shutoff), tank reinstalled, sediment bulb cleaned and gasket replaced and all is hooked up again.
Problem: Tractor fires when choked runs briefly and dies. Adjusting choke or throttle has no effect. Glass sediment bulb filled with gas. If I remove plug from bottom of carb I get some gas but no continuous flow. (Is that norm?) Is this a fuel availability issue ie fuel pump or carb issue? Or air in line/lock situation?
I was strongly advised by the implement guy that sold me the tractor who my bro has worked with that I should not open the carb on my own. I will take that advice.
Wondering if there is anything further that I can try before consulting an experienced Ford mechanic.
Thanks for any advice you can provide. EB
