Anonymous-0
Hi All,
I have a ford 861 with a 12 volt system. Tractor has been running really well and starting easily. However, recently it would just die about 40 minutes into work. Prior to this I have been able to get it restarted but now nothing. As I was trouble shooting, I noted some corrosion on the plug wires so I replaced all plugs, wiring, coil, etc. Still nothing. I have been holding a plug close to the cylinder head and cranking the engine but am not getting any obvious fire. Compression is good and seem to be getting plenty of fuel into carb. any advice would be much appreciated.
