Company Logo Shop Now
Grill on 851 with hydrolic pump
tbone22
07-25-2014 15:34:37
I purchased a 851 with a ford front loader and the hood and grill were not on it. the previous owner (deceased) said it was too much of a pain to put on and left it off while he owned it. I want the protection for my radiator so I put the hood on and started with the grill, that's were I ran into a problem. The grill has a slot on the bottom that the pump shaft goes through but it appears like the clutch on the shaft will rub against the grill when it is installed. I assume I will have to remove the pump and slide the shaft out then put the grill on. After that I will reinsert shaft and replace pump. Is this the only way to do it. I thought about cutting the slot all the way down so i could just slide it on behind the clutch but was not sure that even if I did do this that the clutch would end up rubbing. I really don't want to cut the slot if it is going to anyway or if there is an easier way to do this considering a replacement grill is $250.
i have pictures but it wont let me put them on this post.
tbone22
07-26-2014 16:53:54
 Re: Grill on 851 with hydrolic pump in reply to tbone22, 07-25-2014 15:34:37
Dang I thought I was just going to have to lengthen the slot but I see why no one wanted me to cut this one. It completely ruins it. Get back with me when you get back in town. My zip is 30535 I live in Georgia that way you can figure the shipping.
tbone22
07-25-2014 20:38:17
[URL=http://s655.photobucket.com/user/ihuntcatahuola/media/20140725_181648_zps4dv6met1.jpg.html]third party image[/URL]
[URL=http://s655.photobucket.com/user/ihuntcatahuola/media/20140725_181636_zpse2vcjlze.jpg.html]third party image[/URL]
[URL=http://s655.photobucket.com/user/ihuntcatahuola/media/20140725_181621_zpsay4cdf2z.jpg.html]third party image[/URL]
tbone22
07-25-2014 20:37:12
ok
Texas!
07-25-2014 16:13:51
It doesn't sound to me like you have the correct grille for an 851 because there is no slot in it. Here's a photo of a correct 851. Does your grille look like this?
tbone22
07-25-2014 16:23:12
 Re: Grill on 851 with hydrolic pump in reply to Texas!, 07-25-2014 16:13:51
I do believe it is not the correct hood/ grill it looks like a NAA hood and grill.
wish i could get the pictures to post.
Ultradog MN
07-25-2014 17:03:06
 Re: Grill on 851 with hydrolic pump in reply to tbone22, 07-25-2014 16:23:12
I think it takes about 10 or more posts before you are allowed to post photos - it's an anti spammer thing.
You've got 3 posts now. I doubt anyone here would mind if you made 7 more "test posts" to unlock that feature so you could post photos.
We always like photos here.
Ultradog MN
07-25-2014 16:12:26
Most likely to run the grill you'll have to chop a big chunk out of the bottom of it as the flex coupler (it's not a clutch) goes right about there where the grill/valence is.
That's why you always see tractors with a big chunk cut out of the lower part of the valence and know there was a loader on it at one time.
tbone22
07-25-2014 16:19:09
 Re: Grill on 851 with hydrolic pump in reply to Ultradog MN, 07-25-2014 16:12:26
yeah thats what I was thinking was going to have to happen. Thanks for the input. I will see if someone else has any ideas but that is prob the route I will take. Can't be to mad about cutting the grill up got the tractor with a davis backhoe attachment and ford front end loader for $650. and the motor had been rebuilt a few years ago.. It has an issue with the carb I think the float is stuck I took off the line that goes to the breather and gas poured out. It also revs high so going to rebuild the carb and got a tach on the way so I can get it adjusted right.
Texas!
07-25-2014 21:07:57
 Re: Grill on 851 with hydrolic pump in reply to tbone22, 07-25-2014 16:19:09
That looks to be a fairly straight grille for a 600 or 800 series tractor and somebody will pay a good price for it. You can find one that's already been cut for about $10. !!!!!!!!DO NOT CUT THAT GRILLE!!!!!!1
tbone22
07-26-2014 05:21:55
 Re: Grill on 851 with hydrolic pump in reply to Texas!, 07-25-2014 21:07:57
I havent had any luck finding one, well except remanufactured ones and they are $250. Where is a good place to look for one. Cause this grill is extremely straight with great paint on it.
Texas!
07-26-2014 09:47:50
 Re: Grill on 851 with hydrolic pump in reply to tbone22, 07-26-2014 05:21:55
I have a cut grille that I will give to you free-gratis-nada if you will NOT cut that one!
I'm in Lampasas, TX- where are you located? I get a pretty good discount at FedEx if you are not close. I may be able to ship it to you for $10 or so. Will you pay the shipping charges for my cut grille and save that good grille?
tbone22
07-26-2014 11:51:53
 Re: Grill on 851 with hydrolic pump in reply to Texas!, 07-26-2014 09:47:50
Yes that would be perfect do you have a picture.. either way I would definitely pay shipping for one that is already cut.
Texas!
07-26-2014 12:47:15
 Re: Grill on 851 with hydrolic pump in reply to tbone22, 07-26-2014 11:51:53
third party image
Here's a photo. I will be out of town until Thursday.
NNP
07-26-2014 05:16:16
Texas! said: (quoted from post at 21:07:57 07/25/14) That looks to be a fairly straight grille for a 600 or 800 series tractor and somebody will pay a good price for it. You can find one that's already been cut for about $10.
wow...perfect
agree a thousand percent. Please don't cut it.
The original grills quality is FAR above the aftermarket ones.
If you can't find a used, cut, one. Buy an aftermarket one and cut a hole in it and sell that one
to some poor guy that just needs a good grill to finish a restoration.
or hang it in the barn in case you ever take the loader off........
edit: quick check of ebay found new aftermarket grills for $98...ready for cutting... :D ,
and there is one used one that is cut already for $31.50
This post was edited by NNP at 05:25:33 07/26/14.
Ultradog MN
07-26-2014 05:38:27
 Re: Grill on 851 with hydrolic pump in reply to NNP, 07-26-2014 05:16:16
Another vote for NOT cutting that beautiful grill!!
soundguy
07-25-2014 16:43:42
ditto what UD said. VERY common to have to notch out the bottom of the grill with a loader pump.. etc..
Today's Featured Article - Talk of the Town: What's in Your Tractor's Toolbox? - by Staff. This recent discussion on the Tractor Talk discussion board here at the on-line magazine drew so much response and proved to be so interesting that we wanted to share it with you here. The names of the people participating in the discussion have been left out to "protect the innocent" (to quote a once-popular television series). ... [Read Article]
Latest Ad: McCormick Deering 22-36 Tractor has been restored by previous owner. Runs great looks great. Tractor has automotive paint that is really sharp. Tractor shows really well. Would make a nice addition to a IH collection. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
