Company Logo Shop Now
3 point will not go down
steveks5
07-21-2014 10:52:28
I need help. Have a Ford 841 Power Master. The 3 point will not come down even with motor shut off. Was plowing when it pulled the plow up. Now it will not go down. Thanks for any help. My first Ford.
gatchelguy
07-22-2014 06:39:11
 Re: 3 point will not go down in reply to steveks5, 07-21-2014 10:52:28
Sounds like a stuck control valve spool. Remove the PTO shifter cover and look-see if the spool moves along with the quadrant handle. If not, pry it rearward with the quadrant in the lower position.
soundguy
07-22-2014 15:27:46
 Re: 3 point will not go down in reply to gatchelguy, 07-22-2014 06:39:11
gonna be hard to do that on a 53+ top cover..
Jimmyjack
07-22-2014 06:01:40
If it stays up for more than 4 hours, call your Doctor. Or, one of the Brown sisters said to call her.
showcrop
07-21-2014 18:51:46
As JMOR says oil bath risk. Before removing plug block under one arm so that it can drop only 1/2 inch.
JMOR
07-21-2014 15:29:28
Quoting Removed, click Modern View to seeNeed to determine whether it is a hard-locked mechanical problem that is holding it up or hydraulic. Can the arms be lifted any further up? Have you left substantial weight (several hundred pounds) on the arms overnight to see if they will drop any amount? If you do not have auxiliary hydraulics, you have the accessory plate under the front edge of seat, which has a plug in the top of it. If you remove that plug (oil bath risk) and it drops then it is a hydraulic instead of mechanical lock up. This should get you started in finding the cause.
Latest Ad: John Deere A 1945 styled [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
