146robinson
841 worked hard in 95°+ heat running a 30 ft boom
sprayer ran good stopped idald down and jumped off
to open a gate to go into another field and the engine
seemed to struggle a little to run throuteld back up
and it ran fine and I know I know this is a common
problem and yes heat sheald is on their. And we all
know that the gas was just boiling away in the tank
the problem is I can't get fuel were I live that doesn't
have ethanol and I can't make the temp in Texas
cooler and when I'm in a time crunch to get things
done I can't wait four cooler evening temps.so my
question is what is the all time fix for this common
problem if I were to seek out a fuel additive to get the
boiling point of the fuel up what would it be and here
is another thing I would like some advice on for those
so inclined Google an out fit called hush mat its
supposed to be some pretty good heat reflect n stuff it
might be the way to go for all these guys with old
tractors and new fuel delimmas any way I do have the
fuel line routed a different way it runs up in front of the
muffeler where it is not to close to heat rather than
behind the mannafold. As fare as engine temp it was
running around 190 thanks guys let me know what
you thank sorry for the long post
