146robinson
The tank its self is leaking not the turn valve in the right hand corner side closest to radiator above the oil fill cap there is a support on the bottom of the tank fixed to the tank its self seems to be leaking from this general area my question is are the tank seal up kits you can buy at the parts store (the stuff you pour in and let harden) worth trying I know I would have to get the product to settle in the corner of the tank with out plugging the screen but I thank if I let the air out of theright ffront tire and maybe use a jack I can get it to settle in the problem area have looked in the archives on here and read past discussion on guys using a tank for a Naa so to be clear that tank would work? If I had to replace the old one and would the Naa tank give me the ability to get the 1gallon reserve with2turns n r out my current valve does not have this but would like to fixe the leak if I could /1959/172ci/gas/ thanks
